Arthur Vino
- Mar 13, 2003
I have a question.. Since my pre/pro has a subwoofer filter, I should use it and disable for pb2-plus filter?
My manual says not to use both filters, since some frequencies might not be heard at all... And Crossover filter = phase control filter on pb2?
Thanks...
>Set-Up and Calibration:
>The MB300 subwoofer cable was connected to the left low >level input, and the PB2-Plus low pass filter switch was >set to "Disabled" to avoid filter cascading. After >experimentation, the phase control was set to 180 >degrees, as this provided the smoothest transition from >the mains.
Thanks...
