subwoofer placement remains the same when changing subs?? (1 Viewer)
Brett
I am not entirely sure on this so i figured i would ask. I plan to upgrade my sub which now is a 10" downfire to a larger 12" front firing. Am i just going to plop the sub in the same place i found my current sub sounds best or does each sub have its own sweet spot.. or it just the room itself??
Robert_J
Mississippi
The sweet spot is usually the room. The orientation of the sub will cause a slight difference in response also. I would use the same spot and measure the in-room response again (or for the first time if you have never done it).
mycuu
