Mike Up
- Dec 16, 2002
I previously drew a drawing of my room for another thread but it was an over generalization.
My right wall is completely taken by bookshelves and a giant doll house for my daughter along with shelves above that doll house. The rear corner is the only area open for a subwoofer. It produces over bloated bass with no low bass output at listening position, which is also only about 3' away.
The left wall is encompassed by a very large picture window along with a chair and end table. That rear corner is the same as the other, all bloated mid and upper bass with no low bass output at listening position. Also sub is right behind the chair so it's very loud at that listening position. Testing spots anywhere on that left wall, under the window, produces very weird results. Ultra low bass is good at listening position but mid and high bass are gone.
The rear wall has a sofa and chair with only those 2 corners open as I previously mentioned.
Front wall has no corners as right side of wall open to hallway in front and kitchen to the right side. On the left side of the wall is the foyer where living room door opens. The only spot I get good bass, ok, great bass, is behind the right front speaker.
The problem is I get a null right in front of the listening position so I have to push the sofa all the way to the rear wall. If I have the sofa pulled out, if you're really into a movie and sitting on the edge of your seat (sofa), your head is right in the null with no bass. With the subwoofer right behind the front speaker, all bass frequencies are in the null. With the subwoofer anywhere on the left wall, ultra low and low bass are not in the null, but mid and high bass are in the null and now the null area is larger swallowing up the listening position. The corners have no ultra low or low bass frequencies just over bloated mid and high bass.
Not really looking for advise as I've tried everything already, just tried again. REW and Mini dsp are more helpful with standing waves that add as the mini dsp can reduce those frequencies. Deep nulls are helped most by changing subwoofer or listening positions. Trying to diminish nulls with equalization and power output can just overdrive the subwoofer.
BTW, I tried dual subs with previous Klipsch R-120sw subs and results were terrible. Single sub in this room, works much better. Most likely because I don't have open areas to put dual subs, that would benefit a dual sub setup.
Just "venting", as I miss my days with better rectangular rooms.
