TomCL
Grip
- May 13, 2006
Hi All,
Here's my problem:
I just bought two front L and R speakers for a 7.1 home theater system: Infinity Primus 150.
http://www.infinitysystems.com/homea...d=PRIMUS150BKS
They will have to be mounted on the wall, and they have basic mounting brackets (will attach to two screws in the wall). They will be 10' apart, forming the usual triangle fom the listening area. My room is 12' x 22'.
HOWEVER, I'm now reading about the positive effects of toe-in, which you can't do with the Primus 150's. Only the smaller Primus 140's will attach to a swivel mount.
http://www.infinitysystems.com/homea...d=PRIMUS140BKS
So, do I trade the 150's in for the 140's and two mounts and sacrifice a little bass for the ability to toe in ...or... forget the toe-in all together? What would you do?
Thanks!
Here's my problem:
Thanks!
