Newbie question (1 Viewer)
Darren Siddorn
Hi Guys & Gals, this is my first post, so be nice, I would appreciate a little advice regarding buying a Plasma screen. I have just moved to Canada from the UK, so I am getting used to some AV names I haven't heard of before, and I have seen a plasma display at Futureshop for $2799.99, it is a Norcent PT-4231, the description on the website doesn't give much away and I can't find any reviews of this display, so can you tell me are Norcent a good, reliable manufacturer, or should I stick to the better known brands?
Thanks in advance:D
SimiA
I'd stick with the better known's like Pannasonic, NEC, Pioneer..etc.
You can find these for the $$ range of the Norcent.
My personal bias leans towards the panny. Best contrast ratio and bang for the $$.
Vb
mycuu
