mrluckiest
- Dec 11, 2006
- Tim
This is my first post as a newbie to the board (so bear with me and my fairly long story). I am very frustrated. Due to (WAF), as I'm understanding it's termed, the family room will require in-wall speakers. (the Martin logans are going upstairs for the main HT room). Unlike non-in-wall speakers, auditioning in-wall speakers is pretty much next to impossible. So, how do I decide which in-wall speakers to buy (sound unheard at home)? I will be putting a 50" plasma on a brick fireplace. There are narrow windows on each side of the fireplace. The front in-wall speakers will be on each side of the windows (11' apart). The room is 23 wide, 18 deep. They will be powered by a B&K AVR 202 (5.1). I will also need a matching center channel to to be mounted below the tv to be compatible with the in-walls (WAF dictates black only). My price range is about $1k for the front's, $500 for the center and hopefully a bit less for the rears (give or take a couple hundred for each). I have found very little on the internet on how to decide or compare from independent reviewers. Did each of you just take a chance and bought within the price range you had? Are there (non-biased) sites you have found that rate the best sounding/performing speakers by price? All the home theater stores/retailers all carry their own brands (and naturally that's what they recommend). I'm stumped!!! I'm not wanting to beat this to death, just want to make a good decision. Thanks very much in advance for your input. Tim.
