- Feb 8, 1999
- Robert Harris
Shout, via there special event "Select" label is releasing John Sturges 1960 The Magnificent Seven, and while it's yet another of those Eastman films of the era that doesn't exactly cry out for 4k UHD, it sure does look purty.
I'd call it almost perfect. I'm seeing some oddities, but we'll keep in mind that the Eastman Color elements are now 62 years-old. I'm presuming that this was shot on an early run of the new 5250 stock, which has better dye fade characteristics, but (beyond printer function dupes) there could be any myriad of damage necessitated dupes cut in over the decades.
The opening credit sequence seems just a bit dark, but most folks won't notice that. For the body of the film, things are generally beautiful, with not a problem in sight.
Superb dirt clean-up and stabilization.
Grain structure is mercifully natural, and shadow detail is generally very pleasing, Keep in mind that the film was shot on location, so the camera crew alongside DP Charles Lang were probably in constant motion.
The cast - Yul Brunner, Eli Wallach, Steve McQueen, Charles Bronson et al are wonderful.
And then there's the score by Elmer Bernstein, with one of the best known themes in all of filmdom.
The other huge player here would be Walter Mirisch, an icon who is fortunately still with us at 101. To me, he's a producer's producer. If there's any question about what that means, here's a shot list of some of his accomplishments:
It appears that his 34th film (as exec producer) was Invasion of the Body
Snatchers in 1956. His 39th in the same role was Friendly Persuasion. Coming in at around the 40th is The Magnificent Seven.
Leaving out the numbers, we can add West Side Story, The Children's Hour, a couple of Elvis films, The Great Escape, The Pink Panther, A Shot in the Dark, The Russians are Coming..., Hawaii, How to Succeed..., In the Heat of the Night, The Thomas Crown Affair, Fiddler on the Roof...
You get it.
Audio in DTS-HD MA 5.1 is works nicely, especially as it spreads the music across the field.
This is another of those films that those going in unaware will be highly rewarded.
As part of Shout's Select label, you'll also get the requisite extras, which until now have been the turf of Criterion. Most will be found on the Blu-ray disc, with the 4k only carrying commentaries. This leaves more room for data throughput of the OCN scan.
In short, this is a big deal, and whether the film needs 4k or not is a moot point. We're getting the best possible, and Shout isn't holding back on the cost of the extra disc.
Image – 4.8 (Dolby Vision)
Audio – 5 (DTS-HD MA 5.1)
Pass / Fail – Pass
Makes use of and works well in 4k - 4
Upgrade from old Blu-ray - Absolutely
Very Highly Recommended
RAH
You get it.
Pass / Fail – Pass
RAH
