Chad Seymour
- Feb 28, 2000
Question 1:
For all you beta testers out there, does the headset that comes with the Xbox live setup have a standard input jack? If you wanted to remove it from your Xbox setup and use the headset as a mic on your PC, could you?
Question 2:
I am trying to decide what router to go with in anticiapte of going Live. The Linksys wireless router/4 port hub is on sale at BB for a good price. Has anybody had any problems with going wireless or does your connection definitely need to be wired?
Chad
Question 2:
Chad
