Sammy Sams
- Sep 14, 2002
Any recommendations on how to wire this center speaker would be helpful. Should I use both the center pre out and the center speaker outs?
i've hooked up my clr3000 to my avr5800 using the line-level full range input and bi-wired the speaker-level to the low and mid, with the gold jumpers connecting the mid and high binding posts.It is not recommened to feed the low level speaker terminals and the line level input simultaneously.
When switching from feeding the internal powered woofer section a speaker level or line level (never both simultaneously) you must re calibrate the gain control on the speaker.
well, as i said, when i used only the line-level connect for the 3000 (bi-wiring mid and hi), i got almost no bass at all out the thing, clean or otherwise, even with the gain at full.John,
I have owned two C/L/R 3000's and the internal powered woofer low level inputs worked fine on both.
I only need to turn the gain up to around 9-10 o'clock to balance match the upper and lower sections with Avia's cycling high and low test tones.
Did you call Def Tech and speak with a technician? You and your friends 3000's are defective or your setups are not correct.
I am currently using mine with an Elite 49TX and used a Parasound AVC-2500 pre/pro for a couple of years also with no problems.
I only need to turn the gain up to around 9-10 o'clock to balance match the upper and lower sections with Avia's cycling high and low test tones.see, what i find with my 3000 connected using the speaker-level low connection is that 9 or 10 on the gain is simply way, way too much bass. WAY too much. however, with only the line-level it's nowhere near enough.
where i have the gain now is about 4 o'clock, which is the position definitive said they recommended.
this leads me to believe that you may in fact be experiencing the same thing i am (or else you just really really really like bass). why don't you try this at home: with a prolonged, bass-heavy piece playing, take speaker wires connected to the center-outs on your receiver/pre-pro, and then plug them into the low binding posts on the 3000.
i mean, all you have to do is touch the banana plugs to the low binding posts on the 3000 to see if there's a difference - just keep touching and removing them to see if there's a difference between the line- and speaker-level bass-outputs.
you may be surprised. i was.
- jd
4:00 o'clock, this is with a line level input?balance match said:Quote:
