Wiring Def Tech CLR3000 and Denon 5803
Discussion in 'Archived Threads 2001-2004' started by Sammy Sams, Oct 23, 2002.
  1. Sammy Sams
    Sammy Sams Agent
    Sep 14, 2002
    30
    How to wire this center speaker??
    It has a subwoofer and a 150 watt amp.
    Use Center pre out?
    Use Center speaker outs?
  2. Holger
    Holger Stunt Coordinator
    May 29, 2002
    87
    hi sammy,
    i connected mine as follows: i removed all those golden binding posts. i bi-wired the the highs and mids terminals via a 6mm² cable which is half made (3mm²) of copper and half made (3mm²) of silver. i connected the silver cable to the highs terminal and the copper cable to the mids terminal.
    i connected the low level full range jacket(bass) to the pre-out from my pre-amp. this gave me in my room and for my taste the smoothest bass response. of course this is the most complex way to hook up this remarkable speaker. if you prefer an easier way, you can let those binding posts where they are and just connect a speaker wire to one of the three terminals, it doesn't matter which one.
    hope that helps
    regards, holger
