Gui A
- Dec 25, 2000
Hey all, I was wondering if I could get some networking help, as I'm stumped.
I have a D-Link DI-624 Wireless G Router, and a DWL-G520 PCI Card.
The router is connected directly to a WinXP machine with a LAN cable, and the wireless card is on a PII Win98SE machine.
The XP machine is working ok. It's able to get an IP address, and everything seems fine.
The Win98SE machine is a bit of an issue. I can't seem to be able to get to connect. All the WEP and other settings seem ok.
The signal strength is at 80-90%, and it says "Associated: BSSID" (and then the MAC address of the router).
The router also says "Wireless PC connected" in its status log.
The workgroup name is the same on both.
If any one can offer some advice on how to get the Win98SE machine online and sharing files, I'd really appreciate it.
Thanks in advance.
Thanks in advance.
