RyanDinan
- Oct 25, 2000
I have a quick question that's somewhat related to this:
I have a JBL PB10 subwoofer - it's about a year old. Just recently, I've noticed that I hear a very audible buzz from it. This buzz continues even if I unplug the audio cable running to the receiver, so I don't think it's a ground loop problem.
The sub's power cord is NOT grounded (only a 2-prong). As soon as I plug the thing in, I hear the buzz. I've tried different outlets around the house, and I get the same result.
Someone told me the power transformer may be loose, or going bad. I opened the sub up, and tightened the power transformer's mounting bolts, but that didn't seem to help either.
Im thinking the thing may just be going bad. If I leave the sub unplugged for a couple hours, then plug it back in, the buzz isnt as loud - But it gets louder after a hour or so...
Does anyone have any ideas? I've contacted JBL, and they pretty much told me the same thing....and to have it serviced (I think it's out of warranty now too...my luck).
Thanks!
-Ryan Dinan
Thanks!
-Ryan Dinan
