Which Yamaha (1 Viewer)
Scott Andrew
Hello guys, I just purchased two Cerwin Vega CLSC-12 tower speakers. Now I need a reciever but I want surround. So I am looking at the Yamaha HTR-5760 or the Yamaha HTR-5790. The 5790 has a few more watts but it's alot more money. What do you guys think?
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
The Cerwin Vegas are more efficient than most speakers – which means they put out a lot of volume for the watts you feed them. In light of that, it probably isn’t worth it in your situation to spring for the 5790 – unless it has other features you want or need.
Wayne A. Pflughaupt
Wayne Ernst
Keep in mind, the HTR-5790 features an EQ which might benefit you in resolving some sound limitations in the room you have your system setup in. While the 5760 that I had didn't have the EQ, it was still very good when it came to sounding great.
Matt K P
i liked the 5790 better, but the 5760 seemed like it was anewer model/setup in menus and remote control functions than the 5760.
The 5790 sounded better to me though.
Andrew s wells
Is the 5790 the THX model? I have been looking at that very seriously. Right now I have the 5650, and was wondering, if anyone has heard both and, if so, is it worth the upgrade?
Matt K P
it does have THX, the 5760 does not. ive heard both on the same set of speakers: jbl e60, and with no bass/treble processing or eqing, the 5790 had a much fuller low end.(hz)
tommy_E
i own the 5790....its definitiley worth it...at some places ive seen the 5760 for $350 to 450... i got my 5790 off electronicgiant.com for $529{now the site has the new 5890}
THX...not really a big deal...all a hoax
ciao
Miller112
