ReneA
- Dec 17, 2000
I am about to set up my Mitsu Hi-Def Receiver and am wondering if component video cables are the only way to go with this. Can anyone advise if there is anything better? Thanks.
Component cables are the way to go, but I recommend that you take a look at www.rhinocables.com. Rhino uses top quality Belden 1694a cable, Canare connectors and the workmanship is excellent. Silver Serpents are pretty, but IMO the Rhino's are just as good and cost a lot less.
Before you spend way too much money on cables, check out these guys. Their cables are affordable and are getting rave reviews.
DarrellP,
I like the Outlaw cables. In fact, I posted a review of a blind listening test I did with them just a few weeks ago. In that test the Outlaws unanimously beat a set of AudioQuest Corals that cost 3 times as much. The Outlaws are excellent performers and are a great value.
But the Outlaws are audio cables, not video. Using audio cables in place of video cables can seriously degrade picture quality, especially over long runs.
