Travis G.
- Jun 29, 1999
Where can I get a powerfull quality amp for a reasonable price? I'm looking for a 600 watt home subwoofer amp for about $700 and under.
Many people are beginning to understand the power of a "professional" piece for subwoofer amplification, which does not require as much in terms of sonic quality as your mids and highs' amplifiers.
I have to say,, that no matter what I was powering, be it subs or full range speakers in my HT, I would prefer professional style amplifers regardless.
I would put any Crown Pro or Crest professional amplifier up against any consumer mono block amp or multichannel amplifier- any day of the week. I think barring auphile tube products, a professional amplifier made by Crest or crown would best 100% of the outboard amps available. I would even say that other brands like Ashly and Carver would also kick the crap out of every consumer amp in the same price range.
Your statement above just inferred that professional amplifiers were less appealing for mids and highs due to a lack of sonic quality, but I think you'll find that good pro amps are ruler flat and can power you clean out of your house!
-Vince
We're starting a Home Theater Enthusiasts Club here in OHIO. Want to participate in our discussions and events? Check out the info here .
What is a "raw home subwoofer amp"? Forgive my ignorance, but I've been working with amplifiers for going on 10 years and have never heard this particular distinction.
Are you looking for a plate style amp, like the kind you find on commercial home subwoofer enclosures?
Are you looking for an outboard professional style amplifier, like most folks around here use?
Whatever works. It would be easier if it had it's own housing but it's not a high priority.
Whatever works.
Well, both work. And getting 600 watts (total? per channel? Who knows, you never answered that question) for under $700 will be very easy either with a plate style amp or a professional rack mount unit.
I would say there are probably more than 200 different products out there that will fit your need as explained so far, so it is tough to offer any real advice without knowing specifically what you need.
