teapot2001
- Apr 20, 1999
- Thi
I was using Win 98 until I tried upgrading to XP Pro yesterday. With XP installed, I encountered some compatibility problems (Adaptec CD creater, DVD drive won't play DVDs, etc). That was fine with me, but then I tried downloading a fix for my keyboard from HP, and my system started to become extremely slow (Athlon 700Mhz, 128 MB RAM). I restarted the system several times, but the system was still slow, as opposed to operating fine before the keyboard fix download. It was basically unusable; I tried looking at the running processes and applications, but that window, or any window, was hardly usable. I then tried to use my system recovery CD to reinstall Win 98, but halfway into the installation, there is a problem with the CD drive or the CD itself as it reports (the CD had worked before). I tried this again and again without success. Then my system has a fatal error on start up that requires me to shut it down before it gets to Windows. My only option at this point was to install Win ME from DOS. Everything seems fine now, except that all my files in the My Documents folder are gone. I tried installing XP again, but now there is a problem where it freezes at 59% during the analyzing system phase. I don't know why I'm having all of these problems. So I guess I'm stuck with ME for a while. I'd just like to know why people don't like this OS? From the short period I spent with XP, I liked it a lot, and I am planning on upgrading my memory by 256 MB.
~T
~T
