Je-P
- Oct 18, 2002
I'm looking towards getting a 55" Mitsubishi Widescreen set. And both are sold at Best Buy. They have a 55" HDTV monitor that I could get for $1800 or a 55" HDTV w/ ATSC tuner for $2200. Money's not really a factor, but one thing that is discouraging about the more expensive true HDTV is that only one of its component inputs does 1080i. The other 2 do only 480i/480p. Right now I have a Panasonic RP-82 and a Xbox that I would like to connect component wise. Is the trade off for a built-in HDVT set worth it to lose 2 1080i capable inputs? Here is my situation.
1. I watch a lot of DVDs, and will be supporting HD-DVD, so that 1080i input will be used.
2. I'm also a gamer, and although only one Xbox game does 1080i right now, future games and gaming systems might do 1080i.
3. I only receive the most basic cable broadcasts right now. The local channels plus one or two other channels. I have little to no desire to upgrade to digital cable or Direct TV. It is a plus to be able to get basic cable channels in HD though.
So according to my situation, which of these sets do you recommend? Thanks for the help.
