Not sure if I am using the right terminology but I have a few questions about setting up my HT with a video switch that can handle all my connections.
I need a device that I can used to switch between my different video requirements. What I mean is a this:
I have run RGB 5 for component video (red green blue) from my AV center to my projector. The extra two cables in the RGB5 cable I will use for s-video, and RCA video.
What I need now is a device that I can use to plug in all my different components (ie. cable box, satellite, Xbox, DVD). So essentially something with 5 or 6 of these inputs, and one master output that will connect to my projector.
Can this be accomplished by simply buying the right Digital HT receiver. Or is it better to use a separate device.
Also, I plan on terminating a wall plate which has Component video inputs, S-video inputs, RCA video and Audio Inputs, as well as coaxial Digital audio. HAs anyone seen a wall plate like this. My point behind this type of termination is so that I can simply plug in a video camera or a game console into the wall at the front of the room instead of having to plug them in at the back of the room where my AV rack is located.
Is what I am talking about possible, and if so can someone shed some light on what I might need for equipment to handle this.
