David Proud
- Jul 25, 2000
Two Scrolling Bands Using Component Distribution Amp
I have 2 scrolling bars/bands that move from the bottom of the screen to the top of the screen when using a video-storm hdtv cb003 distrubtion amplifier.
My setup consist of the CB003 HDTV component Distribution Amp sending 1 output to a HDTV upstairs and 1 to a lumagen HDP video processor that sends it to my projector in the theater room. The equipment rack is close to the main AC panel and I have no other place I can put this stuff.
no bars exist on any other sources.
If I run the HDTV box directly to the Video processor no hum bars at all.
I know you will say this is a ground loop but I don't think it is. this is why, I have taken the CB003 and placed it on the same circuit as my projector, hdtv box, and video proecessor and the two bars are still there although at a slower speed.
I hate Lots of Dimmers in the house. so I even went to the trouble of flipping every breaker in all breaker boxes except the ones in the theater room. Still scrolling bars.
I bought a seperate Amp and Inday but it exhibits the same problem. They both use the same power supply and prob share the same internals.
Inday support is going to send me a modified regulated power supply to see if that helps. Anyone recoomend anything I can do to fix this annoying problem?
Any idea what I can do to get clean component HDTV distribution without the bars?
