TV and Blu ray compatibility issue (1 Viewer)
Nekomex
Enrique
I have an LG plasma tv , the tv has four hdmi ports, i have a ps4 and an xbox one connected and working fine, i have a samsung blu ray player that just wont get recognized by the tv.
i have try conecting it with different hdmi cables, including the ones that work with the One and the ps4 and to the same ports, i have enter the blu ray menu with AV cables and changed the resolution to 720 ( i read that that could be the problem) and the TV just displays a no signal message, i had the blu ray player conected some day ago to another tv by the hdmi port and it works correctly. It seems like its a compatibility thing between the blu ray and the tv but i cant understand what can be.
any help?
Malcolm R
Malcolm
Another possibility:
Using an HDMI Cable
If HDMI is being used and the SIMPLINK option is turned ON, this could cause the television to display a No Signal message when manually switching inputs on the TV.
Turn the SIMPLINK option off by pressing the SIMPLINK button on the bottom of the LG remote.
Nielmb
