RichardHOS
- Mar 11, 2003
I think looking at speaker/amp costs as a ratio or from a proportionality aspect is probably not the best thing to do. That's because I see amplification as leaning more towards a fixed cost than highly variable, while I see speakers as much more variable than fixed.
What do I mean? Well, suppose that you're not going to use a receiver, but instead want good, quality multichannel amplification (let's say 5 channels). You can get good, high power and high current 5 channel amps for $2000, maybe less depending on what brand tickles your fancy. That amp would be perfectly capable of running most any speaker you might want to connect to it, excluding some highly demanding low impedance models. That amp would be perfectly suitable for an HT speaker package deal costing $1500, or four pairs of most floorstanders with an expensive matching center costing $15000, and I don't really see either as being an extreme purchasing decision. In the $1500 speaker system, the owner might recognize that a good, quality amp purchase is something that might last him through several source, pre/pro, and speaker upgrade cycles. And the $15000 guy might recognize that in his moderately sized room, he'd never need more power than that no matter what speakers he might purchase.
In my case, because I've chosen to actively biamp each channel of an elaborate multichannel system, I'll have roughly $7000 in amplification (with approx. $10000 total speaker cost). But once in place, I'd be absolutely comfortable using that same amplifier stack to power $3000, $30000, or $300000 worth of speakers (I don't see 6kW being inadequate for any speaker setup that would fit in my house).
