TrevorG
- Mar 2, 2001
I have just received the set and I so far have went throught the SVM disabling and doing the service menu convergence. I also did the electrical focus which also helped. Which by the way was very bad out of the box along with severe bowing. Anyway, this is now as close to perfect as I can get it. I have a Panasonic H1000 connected to it and it looks stunning!!
Here is a description of a possible issue:
There is a 4 or 5 inch horizontal line that is less than 1cm.wide. It is in the middle and 5 inches to the left of the screen It is only noticable during brighter scenes but, it is alwys there. It seems to be a brighter line (spot) on the screen and now that I noticed I am obsessing on it. It happens on ALL inputs and also cable or Dish. It is difficult to see but, It is definetely there. Is this something I should have looked at or is there something I can try to help this problem (if it is one) any help/suggestions would be great. Thanks in advance.
[Edited last by TrevorG on September 04, 2001 at 11:02 AM]
