Stacey_V
- Mar 2, 2000
A friend of mine bought a 55HX70 about 6 weeks ago. From day one, there was a smudge on the lense, in between the lense layers. A service tech was called out, and he deemed it defective, requiring replacement. After 5 weeks of waiting, it was finally replaced last night. Here is where the fun begins. My friend commented to the tech guy that the image was a bit soft, and he would like a focus done on it. This was prior to the lense being replaced. These are the steps he apparently did to the set:
Replace lense
Do an electro focus
Do a mechanical focus
Did the greyscale (by eye, no less)
Did the convergence
The set is now pretty much unwatchable. The only part of the picture that looks half decent is the center of the screen in a 10" radius. The image gets blurrier as you look out toward the edges. If you were to display a pattern of cross hatches, the outer edged ones would blur.
eg. A cross hatch in the top righ corner, now blurs upwards and to the right. A cross hatch in the bottom left corner, now blurs downward, and to the left.
The techie tried for quite sometime, and finally resigned himself that Toshiba would need to be called. My friend thought that the original screen was different than the replacement that they brought out. He remembers the original screen being smooth on both sides, whereas the new one has circle patterns on one side that you can feel by hand. Is it possible that they replaced it with the wrong screen? Any other ideas as to what could possibly be wrong?
Thanks for all replies,
Stacey
Replace lense
Do an electro focus
Did the convergence
Stacey
