Scott_AH
- Sep 26, 2002
I've recently noticed some strange bending in the picture on the left and right sides of my Toshiba. When I'm running an s-video connection from my X-Box, the left and right edges bend inward. The middle of each bend comes in about a quarter inch or so while the top and bottom parts actually extend a bit beyond the edge of the screen. It's not nearly as noticeable when I'm running a composite connection but I can still tell there's a problem. When an image moves horizontally across the screen, the top and bottom portions look just fine. The mid section, however, seems to bend as it moves across until it's about two inches from the edge of the screen. It then looks fine as it moves until it trails off the other side and the same thing happens. I think the same pincushion problem is happening but I just can't see the edge of it. Does anyone know a fix for this? I'm sure it's only solved through the service menu but so far the only setting I've messed with is the vertical height adjustment in order to fake a "compressed mode" when I'm watching DVDs. I don't want to go in blind and start messing with random settings until I find one that works (or royally screw something up) so any advice would be greatly appreciated.
Scott
Scott
