Bob Christensen
- Dec 3, 2001
Well, yes, and no. If the null is caused by a room interaction, it will come back, but not nearly as strong as before, because it will be proportional to the amount of attenuation you cut the other frequencies with. If it is caused by electronic issues, such as poor XO management or driver matching/impedance spikes, it may come back stronger (or not depending on the issues involved). There are so many factors influencing in room response that it is difficult to "make it simple".
