ClaudeL
- Oct 31, 2001
Ok. I all deleted my post. LOL Before posting my results, I will test my sub in a better means. I think that I wasnt at the right place for the test. There was more bass behind me and i can go nearer the wall when the bass punch more. I cant test right now cuz my parents sleep
but ill test my sub tomarrow.
Tom, you will understand why I told ya that my sub is very strong in the upper bass range. I would like to have a sub like that but stronger in the low end, and more accurate... If you suggest me a sub which is less punchy that mine, forget that lol! Some people think that a SVS PCi cant stack up against mine for the upper bass. Please dont take it bad, I dont want to put down ur products and Im sure that your SVS are damn good... better than mine in overall. But I still want THAT FREAKY upper bass punch.
Stay tuned...
MY RESULTS:
In my bedroom
PS-1000 Frequency Response at Listening Position (3 meters away)
======What I read=====Radio Shack compensation
80 Hz......107 dB.....108.5 dB
63 Hz......111 dB.....112.5 dB
50 Hz......116 dB.....117.5 dB
40 Hz......110 dB.....112.5 dB
31.5 Hz....97 dB......100.0 dB
25 Hz......89 dB.......94.0 dB
20 Hz......82 dB.......89.5 dB
20-63 Hz average SPL: 104.3 dB
Max SPL with material: 116 dB (sub only)
Room dimension: 1470 cubic ft
Notice the high SPL in the upper bass >40 Hz. There is a big difference between 40 and 60 Hz probably because things vibrated so much at 50 Hz that was CRAZY (so objects contribute for a higher spl maybe lol!)
Im gonna do the same test again just to see if the results are ok. I didnt make the sub bottoming out... I tried to test all the thing without audible distortion. If some value change... im gonna update this post.
Secondly I want that you get this. I dont post these results to proove that my sub is better than another. In fact I think that my sub is poor lol (accuracy, boominess)! So I post these results more in order to make you think of what new sub I would like to have. You see these high SPL numbers in the >40Hz range so you know that I want a sub more powerfull as this one, more accurate and more musical. Thank you for advicing me if you will
Stay tuned...
MY RESULTS:
In my bedroom
