Owen Bartley
- Nov 11, 2002
I'm FINALLY done my Tempest! All I can say is great guggamigga the thing is big. I'll have pics of the construction and stuff up soon, hopefully after the weekend. But for now I'm just breaking it in and playing around tweaking. Once I set the phase a little better and played around with the gain, the levels from the receiver, and the tone controls, it started to blend in really well and sound great!!
Now I'm just working on a few post-construction, pre-finishing things. First off, I'm looking for some more test tracks. I've used LOTR (the typical chapters), Blade II (the whole movie), and the helicopter explosion from Matrix (sounded awesome!)... I'll give SW:Ep II a try this weekend, and I was thinking about renting Titan AE and Maybe U-571 (or 751?) because I've heard they have some pretty goos bass scenes. Anyone else have a reccommendation?
Second, I'm noticing that not a lot of air is coming out of my port. It's a 5.5 inch sonotube, and I'm fairly sure my box is sealed pretty well, so I'm just wondering what kind of movement I should be getting. I think in my LspCad sim it showed around 15m/s, but I'd have to double check when I get home tonight. Do any of you guys with larger ports have a lot of air flow?
Thanks!
-one satisfied Tempest owner
Thanks!
