AndrewGault
- Nov 22, 2002
Would a Carver M-400 power a SVS 20-39 CS-Plus alright to get the full potential?
I was looking @ the PC-Plus but I think the CS-Plus has a better driver or something like that...Not true. The PC-Plus is a CS-Plus with a built in amp. It has features the CS-Plus does not have (e.g., settable subsonic filter, phase control, crossover).
I second the advice to go for the PC-Plus over the CS-Plus and a used amp.
You would be hard pressed to find a better amp than the 525 watt amp that comes with the PC+ for $250.Make that "impossible" and I'll second that notion.
525 watts RMS into 4 ohms, cool running Indigo BASH technology, auto-on, 4 position SS filter, infinitely variable phase control, defeatable crossover, and input choices galore.
Get the PC+: The TC dB-12 driver and that amp are a marriage made in subwoofer heaven.
Ed
Well actually the B-Stock 20-39 PC-Plus that just happened to show up today did.The same thing happened to me about a month ago. I had been thinking about getting a SVS 25-31 PC+ for some time. I happend to look at their B-stock one day and there it was. Even though it was only $50 off it was enough to push me over the edge. Congratulations on your purchase. I'm sure you'll be happy with it.
Jay
