Dave_Olds
- Apr 24, 2002
Attached is a layout of my room I am turning into an upstairs theater for typical HDTV, Sports and some movies.
The surrounds really have me stumped....I cant figure out the best way to install them and which ones to choose....I have monopole RTi4's - but I could return them for FXi3's if they are a better choice for my application.
My dilemma is the little "cove on the left side of the room.....Right now, I have the LS on a stand about 1ft from the wall...This puts the surround slightly ahead of the "L" on the sectional.....I would like to keep the tall hutch/divider for placing surrounds in 7.1 format later but if it is a better choice for 5.1 surrounds I will do it....Or I could wall mount them BEHIND the sectional....I would like to make the seating on the left side of the room still viable though.....
I am not looking for a perfect solution - compromise is ok (I have a dedicated theater downstairs)......Mostly concerned with the speaker choice - are monopoles ok? or do I need to swap them for the more expensive di/bi poles FXi3?
But ANY layout opinions are GREATLY appreciated...!!!
