Though I'm no expert, my first reaction is that's a bad idea.
You want a sub on a solid base, particularly if you want to 'feel' the rumble or punch.
If it is in the ceiling, I would presume that the wood beams would act almost like shock absorbers, reducing the overalll effect. You would lose some of the speakers output plus the cabinet itself would not resonate as well.
The 'rumble' of your woofer would be carried through your ceiling rather than your floor, so you'd not feel them as much. (though anyone UPISTAIRS might!)
I'm sure theres plenty more I'm missing, and I may be incorrect, but IMHO I think you'd be happier the traditional way.
I should ask, for other posters, why you'd want to do that.
Cire, go into the DIY section of this forum and search for IB or Infinite baffle subs. You can make one heck of a sub using your attic space or a closet.
Eric I will have to very much disagree with you.
You do not what a sub's cabinet to resonate, you want it as dead as possible. You only what the driver transferring energy into the room.
A proper manifold properly connected to joists would have no shock absorber effects. If you mount in opposed pairs you won't transfer any mechanical enegry to the joists.
The air movement does the shaking. Won't matter if it's on the roof or floor, if it can move enough air to shake the floor it will.
Finally, Jeffrey has lead Cire in the right direction. Many people whos' ears I very much trust consider an infinite baffel sub the ultimate in sound quality (second only to a dipole sub). I want an infinite baffel, and I do intend to make one happen. Hopefully in the not to distant future. If you can do an infinite baffel, you owe it to yourself to build one.
Everything you need to know about an infinite baffel sub can be found here: http://f20.parsimony.net/forum36475
Note the FAQ and install pics links at the top.
Soon you're gonna be telling me I'm spelling theatre wrong too aren't you Brian. Don't you know baffle is spelt baffel in Canada :p)
Damn it, I swear I never even noticed I was spelling it differently than everyone else. Even with the big print on the IB Forum. Maybe I am dislexic
I stand corrected about the ceiling sub, though I was not considering the IB. (I am too noob to even have known what it is, thanks for the info! If I had talent I'd try to build one!)
I presumed he wanted to take a box-sub and place it in the ceiling.
I should mention, I'm not looking for a box to resonate. But it absolutely does transfer energy to the floor. Just sit on top of one and feel how much energy is transferred to your jewels!
That transfer may or may not be good, but having it in the ceiling (which usually is less stable then a floor) I'd expect it would only cause more room resonance. Maybe I'm noob, and if I'm wrong (again!) please correct me, but I'm sure others here may be thinking the same and need correcting too. I'm just brave (read:dumb) enough to say it out loud.
Dustin,
You Canadians always spell stuff wrong, Ehh !
Hey it's okay I always say "Carbon Fibre" and I live in
the US!
Do you have Tyres on your car? Or Tires?
*We now return you to the previously scheduled topic*
I know that JBL makes a ceiling mount sub. It's a recessed model used in alot of commercial applications. I doubt they'd afford much punch for HT, but they don't sound bad at all in music applications.
Dustin,
You Canadians are as bad as the Brits with your spelling! I won't argue about the spelling of theater as long as you pronounce it correctly! It drives me bonkers when I hear people say "theAter".
No you are right there Eric. Most commercial subs aren't built solidly enough to not flex.
Try sitting this one, doubt you'll feel much for cabinet vibration from it: Link Removed
Weighs roughly 350lbs. It's what the Aerial SW12 should have been :p)
In 1985, I purchased a JBL L380. It is one solid piece of furniture! Its shipping box finally succumbed about in 2000, and I am wondering how to create a new one without involving a carpenter
Had it reconed last year, fabulous sound still.
