jason celaya
- Jul 1, 2001
I recently adjusted my denon 3802 speaker level settings using VE and a radioshack analog meter. I believe I've read in the past that the meter reads 3 db lower than the actual and that VE is ajusted so that if you calibrate to 75db you are actually setting it at 85db. Is this true? So if the sound meter measures 75 across the board you are really setting it at 88db?
Please help-
Please help-
