bradlawson25
- Oct 29, 2015
- Brad
Basically I have two 8" subs(with freq. response range between 20 to 400) connected to a Crown XLS1500 Amp which gets it pre-out signal from the sub woofer track. I have the HD 5.1 trailer for Mad Max. When i put the amp in "bypass" mode it doesn't have as much bass as when I put it in "Low Pass" mode set to 200hz. This doesn't make sense to me, Low Pass mode should only be allowing freq. below 200 hz, In bypass mode it allows anything that the subwoofer track is putting out. So if the sub track is putting out sound between ranges 300 to 20hz than the sub is getting all of it and there by more bass, but if the sub track is only putting out 200 to 20 hz, than bypass mode and low pass mode should sound the same.
So I can't see a situation where low pass mode should have more pass than bypass mode when the pre-out source is a subwoofer track.
Any thoughts or opinions?
Brad
Brad
