I just received my new Mackie HRS120 sub a week ago and wanted to share some of my thoughts, and experiences with this sub in hopes that it can help someone in their search. Due to my amazing hot hot wife I have been driving it with a Denon 3803. For anyone that is considering buying a higher end home class sub ($1000+), I would highly recommend placing this studio class HRS120 on your research list.
Looking for a sub to use for 50/50 music/video is not an easy task. Initially I auditioned a couple of home class subwoofers from Velodyne HGS, and VLF series since my brother in law owned both. I also had the chance to hear a smaller tube SVS along with a Klipsch 12 inch reference ($1500 wow expensive!). Along with these higher end models I heard a smaller Boston Acoustic, and a Polk, in the $500-600 range but I haven’t heard a HSU or B&W. I have to say that although they all seemed good they did not really clearly stun me (except perhaps the HGS 12’’ Velo due to its size). Having some experience in the pro audio field I decided to hear the HRS120 since I know some movies and music are mixed using this sub and sister monitors.
I have to say that I was floored with this studio class 12 inch 400 Watt servo sub. Since this sub is used in recording with +4dBu balanced XLR it is preferable to run it that way, however it also has the standard –10dBV RCA inputs (due to THX requirements) which I am currently using with my input sensitivity (kinda like gain) set at about 1/3 or < -10dBV. Eventually I will place a DBX DriveRack active RTA between it to correct for room modes, room response, and frequency timing but for now I have been running it pure.
In one word I can say that this sub is amazing. I nearly killed myself carrying it into my home since it weighs 94 lbs (almost as much as my wife hehe). I have never heard such accurate tonality from any sub in my life. Further more it is loud, easily reaching reference levels in my 13x16x12 room making my neighbors none too happy
. I am sure that it could not compete for SPL with an 18inch Velo, but then again it is much more accurate not suffering from transducer (woofer) distortion and costs far less.
For music it is beyond compare, and would be perfect with a pair of HR824 monitors used in the industry to mix the CDs. For movies some might prefer a sub with more distortion as this can add to explosions etc. although I prefer accuracy. As with all subs compromise is at its heart and the HRS120 is no exception. How do you get this kind of extension and control from 12 inches? A bigger box. While this sub is not bigger than a HSU or SVS, it is not as small as the Velo HGS series. If you can find it at $1100-$1150 it’s a great deal and pro audio usually has a much better price/performance ratio than home audio. It has a big brother for those that can’t ever have enough, the HRS150 for $2000 MSRP with 900Watts 15’’ woofer that is now considered the standard for subs. Way too much for me
On a final note I would also like to say that it’s built like a tank using thicker than standard walls (my kid will be able to bang on it all she wants), heavier and larger magnet than home stuff, and true AB class fast response low distortion amp for heavy use.
For those that like technical details, here it is
Sub is ruler flat +-1.5dB from 21-150Hz and –3dB at 19Hz.
Max SPL: 117db @ 1m
Subsonic Filter flat/15Hz, 18dB/octave filter
Filter bypass In/full range (THX)
Filter Select Variable/110Hz elliptical high cut
Polarity 0°/180°
Variable crossover 55Hz to 110Hz, 24dB/octave Linkwitz-Riley filter
THX PM3 studio certified if you care about that
0/+10db switch for recording THX and DTS tracks
Signal pass through / pedal mute
RFI protection
Sensitivity at 7.5dBu/ 1m : 100dB SPL
Distortion: 0.02%
S/N ratio: 107dB at 350watts, 8 Ohms
45 mm cone excursion / 4 inch voice coil
2 12inch transducer (1 active down firing, 1 passive front firing)
Weight: 94lbs
Here’s the website
http://mackie.com/record/hrs120/
The owners manual has a lot more tech info
You can also see a picture of its rear panel online
If anyone has this or the HRS150 I would love to hear your experience and your placement in the room.
James
Max SPL: 117db @ 1m
Polarity 0°/180°
RFI protection
Distortion: 0.02%
Weight: 94lbs
Here’s the website
James
