Ralph Summa
- Nov 6, 2001
How do you guys feel about this?
I just upgraded my speakers from a Bose Acoustimass system. My speaker wire runs were previously split to go in and out of the bass module. Now, I would need an additional 65 feet of wire to get the rears connected with "home runs". I was thinking about splicing the split wires together and connect with electical wire nuts. All my wire is either 12 or 14 gauge Monster XP so I hate to just replace it completely since it was expensive.
The current wiring is contained under the floor and within the walls and so it's not a slam dunk job. I can use the current wiring as a fish so it will be easier than the initial install. It's also a pain in the ass to get behind the receiver and I may have to disconnect most of the components to do so.
Should I buy all new speaker wire go through the hassle and rewire totally?
Should I splice and solder? (Wanted to avoid soldering of possible.)
Can I splice and use wire nuts and not degrade sound quality?
Any potential damage to the speakers receivers?
Ralph
Ralph
