Keith_Current
- Jan 30, 2006
Hello again,
While my brother in Law is installing my Floating floor I plan on working on the wiring prep-work using PVC pipes and hide them in the Drop Ceiling.
So Im searching for Good speaker wire so many types. I do remember when looking for speaker wire you want your wire to be braided n a 45 degree angle. I plan to create my own Component A/V cables for my Equipment. So I just need to find a good wire that wont break the budget.
Could some of you wire junkies give me some Specs on what to look for and what to avoid?
thanks in Advance.
-Keith
thanks in Advance.
-Keith
