brentSkieb
Grip
- Feb 2, 2006
I've run across a stumbling block while trying to calibrate my speakers and hope someone has run across the same type of issue or has some advice on how I may resolve this.
I have an Onkyo TX-SR800 receiver and I first tried to get my speakers as even as I could, using my receivers own calibration system and an SPL meter
(All spkrs. set to small and X-over at 80hz.).
Then, I started with the Avia disc and an SPL meter to calibrate them accurately.
The problem is, when I need to adjust each speakers level independently according to the Avia test tone, the only way I'm able to accomplish this is to go back through the receivers own calibration system, which has at a totally different tone and volume than the Avia test tone.
What is the proper way to take care of that as it makes it almost impossible to calibrate? Am I doing something improperly?
Any help,suggestions or solutions would be greatly appreciated.
brentski
brentski
