John Menoni
- Feb 29, 2004
I was wondering what the best way to crimp the bannana plugs onto the speaker connections and to the pre-amp. I asked the engineers at M&K sound. They are great guys over there and always provide me with a ton of info whenever I ask them a question. The problem is that I usually am more confused after reading the info than before. They gave me all this info and said that the connection should be air tight. I had no idea that the connection had to be air tight. They said to solder the wire to make a good connection. Can anyone tell me in simple terms how to make a good airtight connection for my speaker cables? I want to get this right the first time. Thanks for the help.:b
