Jame pc
- May 24, 2005
This may be the incorrect forum but just let me know where it's moved to moderator.
Some of my HD channels are pixelating and some analog channels are fuzzy. I will be calling the cable company but I like to be informed before I do.
The supply cable on the side of the house splits before entering the attic. On the splitter the "Tap" outlet goes to the TV's and the "out" outlet goes to the cable modem. Is this correct or should the modem get the "Tap"?
Has anyone used one of those plug in signal amplifiers? Can they be used on a digital signal?
James
James
