Adam Sanchez
Hey all,
I almost feel weird posting this but you all have helped me on some odd off topics before so I am sure you will come through again. This is going to be a long winded post to come to a point I am almost already sure of, but then to ask of a possible solutution.
First off you need to know my situation. I am living with my grandparents while I attend school in San Francisco. I have been here since last August. They live in a house they have literally lived in all it's life, which is now over 50 years. When I moved in I brought my shower head with me. They just have a standard deal (shower massage I think) but I have a nicer one with the hand held shower and multiple settings. So I hook mine up no problem. House has good water pressure, really good actuallu and I enjoy my shower.
It's important to note that thishttp://www.neatitems.com/images/Flow_Control_Valve.jpg
is installed on the pipe before the showerhead. It was already there and I didn't remove it. I think my grandpa is the only one that uses it to cut off the water while he washes up.
Anyway several months go by. About a month ago, I noticed the shower head had lost alot of pressure. I thought maybe it was just getting clogged and I frankly used it as an excuse to buy a new nicer shower head. I liked the one I had but only used about 2 settings. So I got a newer one (A Waterpix Shower Massage, just like I always get.
It works perfect for a few weeks and then I realize it all of a sudden has really crappy pressure! So I take the thing off the pipe and have a look. I quickly find the problem. Inside the very top end of the shower head where it connects to the wall pipe there is a "Filter" that keeps stuff out of the shower head itself like rocks or whatever could get in there. The filter has been crushed but only a few are still open to let water through... and there I have the cause of my loss in water pressure.
I dont yet think about WHY the thing is crushed. I go get the other shower head (which I had saved) to pull out it's filter and notice it too has been crushed!
I have searched in several hard ware stores and can not find a replacement filter... maybe a more sturdier built one. In the mean time I used a mesh screen to make a filter in the neck of the shower head bracket just so it will have a screen, but it does not slow water pressure at all.
This morning, my brother emails me to tell me the shower head has broke. For those who have seen a hand held shower head. The neck connects to the pipe in the wall and the water shoots to a dead end (past which is the holder for the shower head) and 90 degrees down is where the pipe hose connects to go to the shower head. Right at the dead end the plastic has cracked and now sprays water towards the wall.
Getting to my point... finally. I need to find out what is causing this. My theory is it's the water saver thing I mentioned earlier. I am thinking maybe having it off and then suddenly letting the water flow is slamming into the filters and shower head and literally crushing them. Does that sound about right?
Should I take off the water saver? Or is there something else I can buy to slow the pressure a bit? Right now, with no filter screen in place the water is almost TOO strong. The hot water runs out too fast in the morning.
I also need to find a new shower head filter screen if anyone knows where I can buy one... preferably more sturdier. Like I said I have the WaterPix "Shower Massage" line http://www.showermassage.com/product...45#LargerImage
Is it possible my shower head is just not a good match for this house? Even if I take off the flow saver, is it going to be a "ticking time bomb" before the water punches through another shower head neck or filter?
Thanks for reading. Hope someone can help!
