Michael Eriksen
- Nov 18, 1999
Hi,
I have the AT 450 system, including the subwoofer, 452PBM.
I have a fairly large room at about 1500 cubic feet.
I have the AT 452 placed in a corner close to the listening position which
is about the best spot...I tried almost all.
As I want more bass and the SVS shipping costs to Denmark are high, I just
bought the servo-15 which I will get in next week with the x-30 controller.
I would like to continue to use the AT sub if thats possible...but I dont
know if its such a good idea to use 2 different subs.
Is there anything I should be aware of ? Perhaps some different settings in
the 2 subs ? Maybe setting the crossover at the servo lower then 80 hz ? Or
should the crossover be the same for the two ?
I have the Denon av1-se which is always in THX mode and sends all bass below
80 hz to the sub. All speakers are set to small.
I just need some guidance towards which things I should try and be aware of
while using these 2 subs in my system.
Any feedback would be greatly appreciated.
Thanks In advance
Michael Eriksen
Thanks In advance
Michael Eriksen
