jrlaw
- Dec 26, 2006
- Jim
My Samsung HLS-7178 is a little over a month old and I am noticing a very weird problem. Every now and then I get two light bars of light, a couple of inches in size, which run down the screen vertically about 1/3 of the way from the left side of the screen. It almost looks like a reflection of light (but it is not as it appears with all lights off). The problem appears very sporadically and does not depend on what is on the screen (blacks, colors, HD, SD, etc.). The bars stay for a few seconds and then disappear. Sometimes they will not appear at all during a show and sometimes they will. It almost looks like there is a light leakage from the edge of the screen. It kind of looks like the vertical light you would see if say you shined a flashlight into your camcorder. Weird problem...anyone else have it or know of it?
Thanks!
Thanks!
