PhilipD
- Jun 24, 2003
I had a post the other day about the best option for a living room where ambient light may be a problem. I had pretty much decided on the 42" plasma, but then I went to our local electronics store and saw the Samsung DLP displays. Now I'm really confused because they are very bright and seemed to have a good picture.
(Side note: as I'm sure many of you have experienced, side-by-side comparisons at an electronics store are pretty much a nightmare. None of them ever have the capability to look at two displays under similar lighting conditions with the same source material. I'm sure they do it on purpose, but it sure is frustrating!)
Now I'm in a real quandry: do I buy the Samsung HLN4365W or the Panasonic TH-42PWD6UY? Both are very close in price through internet merchants, features are tough to compare, although the Samsung stats show higher resolution. Flat plasma is nice, but size isn't a constraint for me.
I'm interested in opinions as to which has the better picture.
(Another side note: if the concensus is that the Samsung is better, I'll probably spend the extra $500 and get the 50" model. As you know, to get a 50" Panny plasma it would be a lot more)
