DonnMac
- Feb 8, 2005
Here's another basement layout problem. The finished basement HT space is 16' w x 9'h x 22' deep, but no effective rear wall will exist at the 22 foot depth, just a half-height (3') partition. The open space then continues another 28' across the basement, so essentially the rear wall is 60' away from the front wall. My HT question: How will the audio be compromised without a rear wall? The HT plan is for a 3-4 seat front row and a 4 seat 2nd row (on a riser), with a just a half-wall for the rear. The audio only needs to work for the viewing area, definitely not intended to power sound through the entire 60' opening. I realize anything is possible for enough $$, but does the lack of a rear wall consistently compromise any reasonable investment in electronics? Any suggestions would be appreciated. I suppose an easy answer is to build the half wall into a full height rear wall, but that won't fit with the rest of the basement plans. Spousal veto power to the nth degree!
Regarding audio budget, I'm planning for $6K - $8K total in electronics, including speakers.
In a space like this, will the elctronics be able to be appreciated?
Thanks for any guidance.
Donn
Donn
