Mike Camm
- Nov 4, 2003
Hey all ... I need some advice from all you HT gurus....
I just finished putting up my riser section:
http://www.cammsplace.com/htpics/DSC01359.JPG
And I have a question about putting carpet on the risers... Before I put carpet over the risers...
Do I just sand down the edge of the riser like this:
http://www.cammsplace.com/htpics/DSC01360.JPG
OR
Do I put on some 1/2 round on the edge like this:
http://www.cammsplace.com/htpics/DSC01361.JPG
Now.. seeing how I live in Florida.. I dont have a large amount of risers and staircases to reference... But I seem to remember when I lived in Pa .. that all the stair steps had the little lip on the edge... (now I'm assuming the lip is made with 1/2 round) .. Does the lip serve a specific purpose with putting carpet over top.. ? Does it bennefit the carpet.. or have a function.. or just for looks.. ?
And .. does it matter if I use a thicker, plush carpet.. or should I stick with something thin ?
Please help.. I appreciate any advice
Camm in Clearwater
OR
Camm in Clearwater
