BillTHO
- Jan 3, 2003
I am having a problem with signal quality on a run of RG6 cable that is about 100' long. I get a picture, but it is grainy. I've checked and rechecked the connectors, but still won't totally rule that out as I know they are finicky. I've traced as much of the line as I can (this is newly finished construction), and I noticed that the electrician ran the cable parallel to a 120v line in a couple of spots, which I was able to separate by 12" or more. Don't know if there are other concealed spots where the cable was strung alongside the 120v or not.
I'm not able to string a new line unless I take it outside the house and bury it, and I'm not real anxious to do that.
So, that leaves a couple of questions- how long of a run can I go with RG6 before the signal quality starts to drop, (seems like 100' should be ok . . .) and would a line amp be a good idea?
Appreciate any thoughts
