A QA2 reset is a whole service menu eeprom reset. It restores ALL service settings to factory default. It is normally only done under dire circumstances, and all service menu setting must be copied down first, and re-entered later. The problem is, I don't know if it resets the service level convergence settings, which I would like to do.
Marc.
Marc, AFAIK, there is no 'default' for convergence. Every set would be different from the factory. You can reset the 9-point, but I think you already know that.
John Golitsis
Next Big Thing Electronics
Marc, I can confirm that there is no reset for the service-level convergence. I don't know whether QA2 reset affects convergence or not. And I hope I never find out.
------------------ http://www.bus.ucf.edu/cwhite/theater/theater.htm
