MarkHastings
- Jan 27, 2003
I just bought/hooked up my ReplayTV. I am using the Component out to my tv and I have a Digital Cable box. Here's a diagram of both scenarios below: ReplayTV Scenarios #1 & #2
Scenarios #1
I am taking the cable source (RF) and I'm going into the D.Cable Box first, then came out the D.Cable Box's RF and connected it to the RF input on the ReplayTV. Finally, I'm going to the TV via a Component Cable. The ReplayTV menus look amazingly clear so I know there isn't any problems with my component connection, but the cable connection looks slightly fuzzy.
Scenarios #2
I've also done this route. The cable source (RF) into the D.Cable Box first, then I came out of the D.Cable Box via the composite (red, white, & yellow RCA cable) and went into the ReplayTV via the composite input, then I go to the TV through the Component cable. The image looks EXACTLY the same as scenario #1.
I figured Scenario #2 wouldn't look too clean, but I figured Scenario #1 would look better, but it doesn't.
My component cable is a brand new Monster cable. My RF cables are basic cables that I got from the cable company. I know they are all ok because I've checked each one by only using them with my cable box and the signal looks fine for each one. My Digital Cable has always looked great, in fact, when I switch between the output of the Digital Cable box and the ReplayTV, there's an amazing difference in quality. YOu can especially notice it in the station ID logos (in the bottom right of the screen).
Thoughts??????
Scenarios #1
Scenarios #2
Thoughts??????
