Brendan K
- Dec 7, 2002
I am interested in upgrading my home theater system. Right now I am looking at spending no more than $1200, although I could probably convince myself to spend up to $1500 if it was REALLY worth it. This would include new speakers (I would not use any of my current speakers) and a new receiver.
My question is approximately what percentage of this should be spent on the speakers and what percentage should be spent on the receiver?
It would seem to me that the follow receivers:
Pioneer 811S
Denon 1803
H/K 325
Marantz SR4200
Onkyo TXSR600
would all do basically what I want.
However, they range in price from just over $300 to $500.
Based on what I have read here on the forum, the H/K and Denon are (significantly?) better sounding than the others. So... Given that my total budget is constant, would I be better suited to spend more on the receiver (i.e. get the more expensive H/K or Denon) and less on the speakers?
For reference, I am looking at the following brands of speakers:
Axiom
Dahlquist
Paradigm
(any other brand the forum can recommend me)
One thing I have noticed is that the Dahlquist speakers are 6 ohm or 4 ohm. If I were to go with Dahlquist (which seems likely based on reviews I have read), would this affect my receiver choice?
My primary use for this system will be music. I would like it to still be usable for movies, though.
Thank you for any ideas you can give me.
Brendan
Pioneer 811S
Denon 1803
H/K 325
Marantz SR4200
Onkyo TXSR600
Axiom
Dahlquist
Paradigm
Brendan
