I just got a 2 pairs of Mini Monitors ( ) and I wanted to see if anybody could recommend a decent, readily available type of banana plugs? Thanks...
james
Radio Shack Gold Set screw type(solderless) work much better than monster cable. Just run down to your local shack and pick up what you need. I think they are about $6/pr.
If you use the "search" function of the forum, you will find many threads with recommendations on banana plugs (this question gets asked every couple of weeks). Simply search for "banana" in the Home Theater Hardware Forum, searching titles only.
