Question on hooking up my subwoofer (1 Viewer)
Bob McElfresh
Hi Jason. I'm going to move your post to the Subwoofers fourm where you should get more focused response. :)
steve nn
Low is generally considered best, especially for HT. Some will only use high though. If you use one sub for both music and HT, I would definitely go with the low.
jeff lam
San Jose, CA
Jeff Lam
Do you mean "low-level"(RCA type connection)/"high-level"(speaker wire connection), or as you said "low-pass"/"high-pass" as in crossover output?
You need to provide more detail.
To me low-pass means the low pass output of a crossover and low-level means RCA type in/output.
If you mean low-level/high-level, use the low-level. If you mean low-pass/high-pass, use the low-pass.
steve nn
Sorry Jeff--I should have said low-level and I did not read your question as closely as I should have. :frowning:
Jason-Pro
yeah i meant rca or speaker wire connections :)
well on regular stereo mode the subwoofer turned off correct? ive got a Harman/Kardon AVR320.
im thinking of going w/ the lowpass hookup tho.
what difference would i notice in the 2?
im building a 2 cu foot box w/ 1 12" and 2 15" PRs and a 300 watt amp. all from www.stryke.com (talk to him on the net alot).
Kcuster50
